Revit Opening Delay
1 ANTWORT 1
Nachricht 1 von 2
203 Aufrufe, 1 Antwort
Revit Opening Delay
My Revit 2017 has been running quite slow lately and I'm not sure what the issue is. It's updated to the current settings but it's not quite as fast as it used to be. Just clicking the open button just to open a file takes about a minute and linking or uploading anything takes a bit of time. It has nothing to do with the file size itself because it behaves this way without having a file open. Does someone have a solution to this problem?
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: Anonymous
Hello, did you installed 3rd party software add-in lately, if yes try to uninstall first and see if helps. Thanks
