Revit on windows server 2016 error
Message 1 of 8
I have been trying to install revit on a windows server 2016 machine but the setup initialization is failing. Isn’t it supported to run on windows server. Should it be windows 10 only?
Replies (7)
Message 2 of 8
Revit_Whisperer
Message 3 of 8
Viveka_CD
Hi @Anonymous
Which version of Revit are you trying to install?
Message 4 of 8
Revit 2018 but I found that windows server is not supported that is why.
Message 5 of 8
Viveka_CD
@Anonymous
Yes, the Minimum: Entry-Level Configuration for running Revit 2018 is as follows:
Operating system
Microsoft® Windows® 7 SP1 64-bit:
Enterprise, Ultimate, Professional, or Home Premium
Microsoft Windows 8.1 64-bit:
Enterprise, Pro, or Windows 8.1
Microsoft Windows 10 64-bit:
Enterprise, or Pro
Message 6 of 8
But isn't Windows Server 2016 basically Windows 10 64bit?  If windows 10 is support so should Windows Server 2016.  What is different about server 2016 that would cause it to not work.  We are seeing graphic display problems in the 3d views.
Message 7 of 8
Revit_Whisperer
Is there a physical graphics card on the server?
Message 8 of 8
yes it has a NVidia Tesla M60 card.
