Hi Guys,
We have a project with requirements of COBie & Standard Classification. Running through the process I notice some irregularity in the omniclass std, code between the Revit default (selection inside the RFA) and the specified using the Classification Manager.
Is this because of the omniclass version or what?
Thanks and Regards..
Louis..
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @Anonymous
I see that you are on Revit 2017.2, please update to 2017.2.3 and confirm if you are on the compatible COBie extension?
You are welcome to share a file to test on our end. Let me know and I can send you a private upload folder.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi Viivieka,
I dont think theres an issue with that even if I used Revit 2018.
Thanks..
@Anonymous
Not sure if related but Revit have been shipped with an outdated version of Omniclass. They even acknowledged it via the article below:
Hi @Anonymous
The core issue is the format changed in the newer versions of omniclass and to support it out of the box some changes has to be done in the software. I will let you know if I have a schedule update.
Viveka CD
Hi Toan,
It worked I just followed the instruction in the link you provided.
Also thanks thanks to Viveka..
Cheers...
Hi @Anonymous
Thanks for getting back to us! ![]()
I'm glad to hear that your issue is resolved. ![]()
Viveka CD
