Why is Revit not showing the New Project Templates for me?
You need to set the path in the Options menu where your templates are.
The Revit default templates are usually saved here C:\ProgramData\Autodesk\RVT 2020\Templates\US Metric
The directory where Revit usually saves it's templates is in my first response. I don't believe it would ever be in you 'My Documents' folder.
Cheers,
From my first response:
"The Revit default templates are usually saved here C:\ProgramData\Autodesk\RVT 2020\Templates\US Metric "
Bear with me lol this is my first time doing this. I am a first time student lolFrom here, what do i click on?
It doesn't at all look like your in the location that I've directed you. The Revit default templates are usually saved here C:\ProgramData\Autodesk\RVT 2020\Templates\US Metric
The Program Data folder is hidden.
Open the "View" tab in the ribbon, check the Hidden Items box, and it should show up for you.
