REVIT NOT RENDERING
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
2471 Aufrufe, 1 Antwort
REVIT NOT RENDERING
Renders not happening with this file only on any device. Rendering size shows above 10000gb. Normal render on screen not working tooERROR.JPG
1 ANTWORT 1
Nachricht 2 von 2
aRcHiTeCt.JM
als Antwort auf: Anonymous
… it is a known issue with REVIT 2019 when you are in an uncropped 3d view
… first you need to update your program to the latest 2019 release update
… the 2019.0.1 hotfix will fix the amount of GB
..... hotfix 2019.2.1
http://up.autodesk.com/2019/RVT/9CA05B9A-1908-0510-A1B4-FFF7A680FE55/Autodesk_Revit_2019_2_1.exe
…. Or you can go back to your cropped view
… then you will be able to render it
… ckeck as well that your camera isn’t inside of a wall or element… that can cause a black screen
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
