Morning
I feel like I lost 30 years and am waiting for a plot on a pen plotter, only worse because nothing is happening now even on a single sheet or view. I let Revit try and do ONE sheet last night and it hangs up, and same today with different plotter drivers.
I have a Case ticket with Autodesk Case 18450090 created November 23 and no response from them other than creating the ticket.
This is happening in both the 2019 and 2021 BIM360 projects, I was using Bluebeam and switched to DiRoots same issue.
Anyone else having problems?
I do have BlueBeam, not the primary print driver; however, I have just checked printing from 2 different Cloud projects and I have No issues here...
The issue you are having could and most likely is a windows update issue.
Thank you for responding.
All windows updates are current, and the video driver and Bluebeam is up-to-date, along with all Autodesk hotfixes, updates, and patches.
Is the issue project specific? Have you tried the Revit 2022 native PDF export?
Sorry I misread that you could not print in Revit 2019 and 2022, not 2021. No, the native PDF export is for Revit 2022 only.
