Revit not opening Twin Motion
3 ANTWORTEN 3
Nachricht 1 von 4
n010478102F8EA
265 Aufrufe, 3 Antworten
Hi all
I have Revit the 2024 Education version and Twin Motion Education 2023.2.1, and I've installed Twin Motion for Revit; however, when I ask Revit to open Twin Motion, it does not open; there are no errors, and I do not get the loading icon - nothing appears and twin motion does not open.
I have tried uninstalling and reinstalling all apps, I've closed and logged out of all related apps and still no luck.
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
mhiserZFHXS
als Antwort auf: n010478102F8EA
Its been awhile since I had to do this, but I'm pretty sure I had to open Twinmotion manually the first time I went to use it with its latest version.
Nachricht 3 von 4
To open TWIN MOTION IN REVIT OR FOR REVIT , please make sure that versions of both softwares should be same.
For Ex: REVIT 2023.1.4 VERSION you require TWIN MOTION 2023.1.4 only.
Shradha K
Nachricht 4 von 4
andr3sant0s
Hi @n010478102F8EA
There are differences between Twin Motion Education and Twin Motion for Revit.
If you have both installed I would uninstall Twin Motion Education and leave only Twin Motion for Revit. Make sure that you have the right version of Twin Motion for Revit, If you are using Revit 2024 you should download Twinmotion 2023.1 Revit.
Here is the link for the downloads.
https://www.twinmotion.com/en-US/autodesk?signature=Qy1BP9SMQ1voo2dlumRvKwLlt1OB+QSKetI3%2Fs3r3G5rzz...
One more thing, I don't know if Revit Educational gives you the ability to use Twin Motion. Follow the steps I've told you and test it.
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
