Revit needs to update the railing and stair systems (among other things)
It's unbelievable that in 2025, we're still stuck with the most cumbersome, un-intuitive, frustrating design tools in Revit.
All of us at one point expected the railing tool to create:
- properly joined handrails
- glass panels that fit in the corner gaps
- glass panels that adjusted with the gap between balusters
- seamless multistory handrails
- create curved panels
So, when that didn't happen, first thing I did was straight to edit type. I tried hosting another railing to stairs, "spread to fit pattern", adding panels in the corners, experimented with all kinds of joins...nothing worked. After that, what was supposed to be a simple google/youtube search to find a solution ended up with hours of scouring the depths of the internet, only to find dreadful workarounds that requires hours of even more work. Or some that don't even work in all cases.
Turns out that the "panels" in Revits railing system are actually BALUSTERS. Yes, the glass "panels" are FIXED WIDTH BALUSTERS.
Don't even get me started on the STAIRS. A simple option to extend the stair geometry would've saved me a bunch of work. Instead I was forced to play with all the settings and handles , and even then Revit wouldn't allow me to get the desired result. LOL.
If I wanted to model all of it from scratch, I'd have used Rhino instead. Curtain systems is obviously no substitute for stair railings. And I don't have the time and patience to create new baluster family types for every 1" difference in the railing gaps from multiple projects that I'm dealing with.
