AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
revit model tree features
1 ANTWORT 1
Nachricht 1 von 2
roscopeco2000
440 Aufrufe, 1 Antwort
Hello i am new revit having come from a AutoCAD/ Inventor background. I have started creating a bespoke desk in Revit what i cant seem to find as i presense in inventor is a list of model features for example if i wanted to go back in edit a void or extrusion. In inventor all these features are listed in a model tree does Revit have this feature?
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: roscopeco2000
No Revit does not work this way, You just create objects (solids or voids) and place or join them together or cut solid with a void. There is less relationships between the objects as there is in Inventor. But then again the object in Revit tend to be (much) simpler than in Inventor.
So if you want to edit a void you would have to select it in the view and then edit it.
Louis
Please mention Revit version, especially when uploading Revit files.
In Foren verƶffentlichen
