Hi!,
Im facing a glitch in my exporter in revit to .stl model. In my revit file its all solid and no holes, but when I already convert to .stl using Revit Plugins already got the voids. I have attached some images i capture from my model. Thank you ! I hope you can help me about this matter.
Sarah
Gelöst! Gehe zur Lösung
Gelöst von BIMAbhi. Gehe zur Lösung
You can try by below process
Export the Revit model into DWG > Then export the dwg to stl
I did try but it isnt exporting to .stl... I use model in-place casework to model my object.
Copy all the model and paste it into a fresh Revit project and then try to export the stl.
Same problem :![]()
I try to convert to cad but it says its not solid.. autocad isnt my forte coz I only use revit.. when I try to export it as .stl in cad it doesnt appear to the location where it supposed to appear. I did try to highlight everything before exporting it but still the same its not appearing. ![]()
Thank you!
Sarah
Attached the stl and one sanp file for your easy reference.
Hi again!,
I did try it its ok in the software but in the print preview got gaps, same problem
thank u so much!
