Hello all,
I have an existing building and the new extension that I created in Revit.
I want to create a 'realistic' view with the existing building (I have an image) and also the 3D model in Revit.
How can I do it?
Which software I need?
Until now I have the Enscape plug-i n but I cannot get the result that I want!
Thank you in advance!
Export your Revit Image with a transparent background then bring that into Photoshop...
You can get a good quality image and use a decal on a plan with your Revit model
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I set the image as a background and I found a good angle. The problem is that I want to move the building 'back'. How can I do it?
Thank you!
Hi @mairh_tsek
Glad to hear about your progress.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
@mairh_tsek found this thread from the Archives - Google Maps image in 3D view and you are the OP:)
Viveka CD
