Revit model elements exported to DWG missing
Hello.
I have encountered a problem after exporting a Revit file to DWG.
When I open the DWG file that has been exported from Revit, some wall elements are missing (Please find the attached images for further information - walls in the red-dotted boxes are where the problem is)
I have tried turning on the option Preserve coincident lines (Click Revit main button --> Export --> Options, and select an Export Setups tool).
I was hoping it would work, but this didn't help.
Any other suggestions will be very very appreciated!
Thank you 🙂
ennujozlagam
@Anonymous  hello, i tried but i didn't experienced what you had experienced when exporting to autocad. dont mind to post your wall so we can check. thanks
Hi, the file that I am working on weighs too much to upload so I am sending a weblink instead. You can download the rvt file down below:
 http://webhard.gansam.com:80/webhard/download?file=busan1472195154421.rvt
For more informaiton, I am currently using Revit 2017, and the walls experiencing problem are just normal family type.
I hope this file is only used for problem shooting, since it's currently an ongoing project for the company I am working at.
Thank you very much in advance 🙂
ennujozlagam
@Anonymous hello, i'm not sure whats wrong with the file or with Revit 2017 as i have said i dont have any problem with revit 2016 exporting to autocad. i tried to export from revit 2017 to autocad and i get same results as yours. But i'm not too sure this screencast if acceptable to you or you have to wait for some options from others. thanks
ennujozlagam
@Anonymous  hello , have you resolve this issue? thanks
Try to check your saved path, which shouldn't include any non-English words.
Hope you succeed!
User
