Revit Model Checker
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2087 Aufrufe, 3 Antworten
Revit Model Checker
I can't seem to get the new build Revit Model Checker Configurator to open? Reinstalled previous works fine tested on PC & Laptop and did a ton of testing Virus Scanners, Dotnet, Admin, Compatability ....
3 ANTWORTEN 3
Nachricht 2 von 4
Alisder.Brown
als Antwort auf: Anonymous
Hey
I had the same issue.
Seems there is a problem with their latest installer. I emailed their support and they gave me a link o download a different installer. This is the link they gave me: https://www.dropbox.com/s/9fs418ot4mglsl2/Model%20Checker%20Configurator%206.0.6488.27469%20Setup.ms...
Not sure if it will work for you, but you may need to contact support@biminteroperabilitytools.com
Seems to be the same issues as myself. Once installed, as soon as i run it it crashes immediately.
Hope this helps
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Nachricht 3 von 4
als Antwort auf: Alisder.Brown
I have the same problem :
- After downloading the official Model Checker on autodesk website, it did not work.
- I tried your link, it sill doesn't work
Any help on the subject ?
Nachricht 4 von 4
I downloaded it from here : https://www.biminteroperabilitytools.com/modelchecker.php
It worked.
