Revit Model Checker compare 2 parameters value
baotram-bui
baotram-bui
Hello everybody,
I work on Revit Model Checker since few days and I want to compare 2 parameters value of one element. Is it possible using Revit Model Checker to check if this parameter called ‘Input Height’ matches the parameter Height?
azad.Nanva
I don't know what is Revit Model Checker but for this situation you can use the dynamo.
JasonKunkel
Have you tried the "Matches Parameter" or "Does Not Match Parameter" condition? You will need to add more filters and do a good bit of testing, but this filter is what I would start with:
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
baotram-bui
Hi JasonKunkel
Thank you so much for your support, I can use  "Matches Parameter" condition to compare 2 parameters value
