Revit Missing Textures When Using Multiple Computers
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
cnanavati
1849 Aufrufe, 2 Antworten
Hello all
I use three different computers, work, client, and my personal, on occasion to work on a project.  Revit works fine on my work and on my client's computer, but my personal one has the problem.  Whenever I open the file on my personal computer, the structure of the house comes up but the texture does not, everything is varying shades of gray.  If I edit the wall material, the texture library opens and comes up with all the properties and a rendering but it cannot find the texture file, look at the screenshot.  I have tried restarting my computer and reinstalling revit, it did not work.  Any help would be much appreciated.
Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: cnanavati
See the link on instructions to re-install the material library properly.
https://forums.autodesk.com/t5/installation-licensing/revit-2018-materials-library-missing-bdsp/td-p...
And, copy the texture image folder(s) from your work computer to your personal computer if there are custom images. Add the folders to Revit options > rendering > Additional render appearance paths.
Nachricht 3 von 3
cnanavati
als Antwort auf: ToanDN
Thank you for your help.
After completing a clean re install, I think I found the source of the problem.
I found an error message saying that it could not find C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats.  I went to that location to find a folder containing all of the textures called "3".  I renamed it to "1" and all the textures came back to my project.
