Revit Memory Requirements
6 ANTWORTEN 6
Nachricht 1 von 7
1144 Aufrufe, 6 Antworten
How much memory is required for Revit 2016. I have a early 2011 macbook, with parallels and windows 8. I was able to download other Autodesk programs (autoCAD, navisworks) no problem. It wont even let me download Revit and the message states that Revit can't be installed on the current operating system. My mac has 4 GB of memory, is this the problem?
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: Anonymous
@Anonymoushello, you can try to check it HERE. thanks
Nachricht 3 von 7
RDAOU
I have tested Revit 2016 on a 2Gb laptop with bootcamp it worked fine althou super slow but that was just to test ...
4Gb with parallels is more like the lower end of the minimum...With parallels i would recommend that you upgrade to 8Gb, or 16Gb even better ... However, the installation issue doesn't seem to be related to memory
Which Mac OS are you using?
Which Revit version are you installing?
And did you apply windows updates?
Nachricht 4 von 7
DarrenP
are you running  32 bit Windows 8.1 OS?
if this is the case Revit requires a 64 bit windows per the system requirements
DarrenP
Nachricht 5 von 7
als Antwort auf: RDAOU
-I'm using OSX El Capitan Version 10.11.6, and Windows 8 on the Parallels desktop
-I'm attempting to download Revit 2016
-I applied the windows update the day I try to download again, I don't go on parallels very often
Are those memory suggestions basically a minimum requirement if I want the program to run smoothly?
Nachricht 6 von 7
als Antwort auf: DarrenP
My laptop is 64 bit according to the processor type, but only 4GB of RAM is installed, and I can get a max of 8GB of RAM. I don't know if I need those other 4GB for it to be a 64 bit Windows.
Nachricht 7 von 7
RDAOU
It is not a ram issue; you will be able to run it with 4gb...issue is with the Operating System.
Are you sure you are installing on windows? Not OSx?
You can try to go through Autodesk Virtual Agent and download the installation files then extract and install locally on Windows
Link to AVAgent below in my signature if you feel like giving it a shot
