Revit Macro - cannot delete.
Hello all,
I don't know much about Macros and have somehow managed to create a module that will now not delete. As you can see below, there is a macro set-up that was copied from a blog - but it somehow corrupted. I can't seem to use the 'delete' button to delete it.
I've disabled macros for the time being. I've also tried to replace that macro content with different content to create a 'workable' macro - with it still failing. The intent there was to create one that Revit recognised, then delete it.
Does anyone have any ideas what I can do to remove this macro? It's causing massive file lag when opening.
kulkul
Just click the macro and hit delete on your right.
Thanks for the reply Kulkul,
I had tried that - it was bugging out for some reason. I've fixed it now. Ended up having to wipe the macro, and build a viable solution before I could delete. It was odd - not even a blank version allowed me to delete it.
