Revit + MacBook Pro
31 ANTWORTEN 31
GELÖST
Nachricht 1 von 32
4185 Aufrufe, 31 Antworten
Revit + MacBook Pro
Is there any hope that Revit will come out for Macbook Pro someday?
The speed of Mac and the quality of its screens makes it essential that it comes out
31 ANTWORTEN 31
Nachricht 2 von 32
DarrenP
als Antwort auf: Anonymous
many threads on this already
this will probably not happen anytime soon
also an idea on this in the idea board here: https://forums.autodesk.com/t5/revit-ideas/revit-for-mac/idi-p/7981054
DarrenP
Nachricht 3 von 32
als Antwort auf: DarrenP
Thanks for your answer.
If I have seen several threads about this but ask why it seems that nobody knows an answer to this. It's amazing that Autodesk has not found a solution yet.
I know the solution of the partition of the hard disk and the use of paralles, but I honestly do not know what performance the Mac computer can have with these solutions.
Have you used them like that?
Nachricht 4 von 32
Why don't you try and tell us what the performance is? You can also try Bootcamp while at it.
Nachricht 5 von 32
als Antwort auf: ToanDN
That is my problem that the company will acquire a Macbook pro for me and I do not know what performance will be given with Bootcamp.
That's why I was wondering which would be better Boot camp or paralles and if somebody has used it to know if they are going well or not.
The features of the computer are 32GB, 512 ssd, Radeon pro vega 560x I9 with 8 cores.
But I still do not understand to Autodesk
Nachricht 6 von 32
Bootcamp is basically a true ugly PC under a nice expensive suit. It can make use of the entire hardware power so it is better for Revit, but worse for any other Mac applications installed in that machine because you cannot use them while you are using Revit.
Parallels is a virtual machine runs under MacOS so it is slower, but you can iChitChat or whatever at the same time.
You can also propose to your firm to get you a powerful PC for Revit and a MacBook Air or an iPad Pro for everything else.
Nachricht 7 von 32
JJWGallagher
I would advise your company not to purchase a Macbook Pro if it's main purpose is going to be using Windows programs. You'll just pay more money for less performance.
Do Macbook pros still throttle their CPU to keep them cool? If so I wouldn't use it in any professional sense.
Nachricht 8 von 32
Thank you for your answers. As I see that you understand, I ask you another question, the option to buy another PC that is not Max is impossible. Having said that, what would you recommend then?
Nachricht 9 von 32
als Antwort auf: JJWGallagher
I will only use revit. I have always been told that mac is better than windows.
Nachricht 10 von 32
If you only use Revit and your company only buys Macs then use Bootcamp, not Parallels. Or are you asking my recommendation on a PC?
Nachricht 11 von 32
in this case it was in both. What PC would you recommend? I have also been told to use ArchiCAD instead of revit. Your opinion
Nachricht 12 von 32
Any PC with similar specs to the MacBook Pro you posted should work nicely.
I can't tell you what program to use.  If you work for a company then use whatever program they give you.
Nachricht 13 von 32
thank you very much for your answers. Sorry to repeat me, never revit for mac?
Nachricht 14 von 32
I don't know.  I don't work for Autodesk and I am sure even people who work for Autodesk can't answer this question definitely.  They could hire Tim Cook tomorrow and roll out a product, three time more expensive and 'just works', by the end of the month.
Or not.
Nachricht 15 von 32
tgrantdelawie
I would recommend getting the i7 version of the MacBook Pro if I were you.
i9 version thermal throttles itself dude to heat and the chassis not being able to expel the heat fast enough.
Due to the thermal throttling - the i9 runs worse than the i7 (a lower product).
Just a thought.
Nachricht 16 von 32
tgrantdelawie
I mean - any CPU will throttle itself to not cause damage. Comes down to airflow and cooling.
Just the chassis of the MacBook Pro sacrificed thermal design for aesthetic design. The Core i7 version of the MBP runs better than the Core i9 version due to this thermal throttling.
Nachricht 17 von 32
Thanks again, it seems you do not like apple very much
Nachricht 18 von 32
als Antwort auf: tgrantdelawie
Thank you, I had never heard that. is apple failure if it is true that you comment
Nachricht 19 von 32
It is the second that comments the same. I find it incredible that an older version works better
Nachricht 20 von 32
tgrantdelawie
Personally - no - I'm not a fan of Apple, but to each their own.
I'm not keen on proprietary components - especially components that are not user replaceable.
RAM and SSDs in the new MBP are soldered to the main board  and are not user replaceable.
I also am not keen on the pricing and lack of industry standard connectors. The MBP you mentioned run roughly $3k-$3.5k correct? I could do a laptop and desktop (both powerful machines) for the same pricing.
Case and point - I just picked up a MSI GS65 with a core i7-8750, 16GB RAM, 512 m.2 SSD, and RTX2060 for $1400.
IMO - much more power, lower cost, user replaceable parts, and industry standard connectors (don't need to purchase a bunch of dongles/adapters). Maybe the battery life isnt quite as long, but I can live with that.
