Nachricht 1 von 2
249 Aufrufe, 1 Antwort
Revit LT
The trial version of Revit LT does not provide an option to import dgn files.   Does the licensed version of Revit LT allow the import of dgn files?
1 ANTWORT 1
Nachricht 2 von 2
TravisNave
als Antwort auf: Anonymous
There is no functional difference between a trial and fully licensed version.
Also, try not to double-post as it can cause confusion in the forum.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-lt-trial-version/m-p/7254101/highlight...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
