Revit LT
7 REPLIES 7
Message 1 of 8
631 Views, 7 Replies
Revit LT
I want to purchase Revit LT but does it support Structures such as trusses, beams, foundations and MEP disciplines.
Labels (4)
7 REPLIES 7
Message 2 of 8
RobDraw
Did you check the product description and/or comparison with the full version?
Rob
Message 3 of 8
JuanYusta
Hi @Anonymous
Unfortunately Revit LT does not have the possibility to work with MEP Disciplines
You can compare both products here:
https://www.autodesk.com/compare/compare-features/revit-vs-revit-lt
Message 4 of 8
in reply to: JuanYusta
Ok i accept the solution. The comparison goes on today that Shared
Coordinates are not supported between projects. My question is are they
supported within a project ie within a site with say 5-7 buildings. Your
help will be appreciated.
Message 5 of 8
RobDraw
Huh?
There is no need to share coordinates within a project.
Rob
Message 6 of 8
in reply to: RobDraw
Hello.
Shared Coordinates.may not be essential but if we move buildings around on
a site it is a convenient alternative.
Message 7 of 8
RobDraw
Within the same project, the coordinates are inherently shared.
Rob
Message 8 of 8
s.borello
I think you may be missing something with regard to shared coordinates within a project.
