Revit LT will not launch
6 ANTWORTEN 6
Nachricht 1 von 7
724 Aufrufe, 6 Antworten
I have been using Revit LT 2014 for five years with no problems.  About a week ago it suddenly would not launch - it would get to the screen showing recent projects, then disappear.  I updated my operating system from Windows 7 to Windows 10, but Revit LT did the same thing.  I downloaded and installed Revit LT 2019, but that too will not launch, behaving the same way.  What should I do?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
I'd do a clean uninstall/reinstall.  Lose 2014 altogether.
Here's one link. There are others a Google away.
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Nachricht 3 von 7
als Antwort auf: barthbradley
Thanks for the reply. I uninstalled both Revit LT 2014 and 2019, then
reinstalled 2019 only.
Same problem, it doesn't open.
Nachricht 4 von 7
You actually performed a CLEAN uninstall per the instructions I linked you to?
Nachricht 5 von 7
Maybe I did something wrong, I'm going to try it again.
Nachricht 6 von 7
Yes, I followed the instructions you linked to.  It still will not open.
Nachricht 7 von 7
Viveka_CD
Hi @Anonymous
Can you please check if your system is compatible to run Revit LT
Please see the system requirements and recommendations for the Revit product line. A list of certified cards can be found on the Autodesk Certified Hardware page.
