Hi All,
We utilise both Revit and Revit Lt in our office. We have noticed compatibility issues with text when opening a project in Revit that has previously been worked on in Revit Lt. The issue sees any text cut off and over two lines with the second line not visible.
Has anyone experienced similar and if so do you know if there is a workaround?
What font(s) is involved?
Are these fonts installed on all computers involved?
What Revit version did this project start in?
Conceptually there should be no difference between Revit and Revit LT with regard to text features but that doesn't mean the implementation and deployment of the software couldn't have missed something subtle that text requires. You should start a support chat with Autodesk to see if you can isolate the problem to Revit, OS, installation etc.
Steve Stafford
