We have set up an A2 Portrait sheet and title block family based on an existing Landscape sheet that we have already created. Everything looks fine in print preview but never prints as an A2 sheet (see picture). I've tried printing in both landscape and portrait settings.
Hi @Anonymous
Which version of Revit LT are you using?
Have you installed the latest updates from your Desktop App?
Can you share your print settings? Which printer are you using?
Related AKN article: Print Views and Sheets
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Have you checked your printer properties? Ours has a landscape/portrait setting that is separate to the one in revit.
