1. https://www.autodesk.ca/en/compare/revit-vs-revit-lt ~ there is a direct comparison between the two
2. For these applications you need the full versions, otherwise you are too limited in your functions. Revit LT is mainly for architects.
3. There isnt a way to negotiate the prices, Autodesk offers a subscription Service that is the same for everyone.
4. You can change all that in Revit, but be warnend it takes a lot of time to set up that kind of stuff, it is not as intuitive as in AutoCAD and the learing curve of Revit is very steep.
5. Yeah, you can change the colors of the interface in the settings.
I tried my best to answer your questions, i hoped it helped you a little bit
kind regards
As Revit LT user I created video with Revit to Revit LT comparison. You might find it useful:
Tom
