revit lt export to pdf
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
money2312
2592 Aufrufe, 9 Antworten
I am using Revit Lt 2017. I need to export files to pdf so I can email the file in pdf format. The PDF export is critical due to the fact that's what my clients need to do there part of the project. I'm also using  autocad architecture 2013. ACA-2013 has an export to pdf function, which makes it easy to e-mail . Revit Lt does not. the revit program is better since I don't have to deal with the project navigator. otherwise I would use ACA-2013 Is there away attach pdf function for revit lt or another way to export Revit Lt to PDF.?
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: money2312
Print to PDF using any free or paid, cheap or expensive PDF solution: adobe, bluebeam, pdf creator, etc...
Nachricht 3 von 10
Alan.johnson1970
Revit and Revit LT do not have PDF functionality in or out.
As ToanDN said just install a PDF printer and Print to PDF
AJ.
Nachricht 4 von 10
money2312
als Antwort auf: ToanDN
ok thx  but how do I link to the program?
Nachricht 5 von 10
Alan.johnson1970
When you print you select the pdf printer
AJ.
Nachricht 6 von 10
money2312
will this solve my emailing issues ?
Nachricht 7 von 10
Alan.johnson1970
When you print to PDF it just creates a PDF document like built in PDF export options in other software..
So this will work ok for you to email the PDF
AJ.
Nachricht 8 von 10
money2312
als Antwort auf: Alan.johnson1970
Wonderful. Thank you.
Nachricht 9 von 10
money2312
adobe pdf is not in the list of selections. what do I do now
Nachricht 10 von 10
Orsolya.Balazs
You may install  Cute PDF writer from internet instead. After installing the PDF writer the appropriate driver to use will appear at the print dialog:
Orsolya Balazs
Product Support Analyst - AEC
Autodesk, Inc.
