I have created the dome with “Walls in place” tool using sweep, but the windows, I put in it will only stand upright and not according to the wall’s shape. Furtermore- the walls will not show the material, I put on them.
You either need to make some Face-Base Window families or you can use Model In-Place. The Face-Based would be better for multiple windows that are the same. If they are all random the second might make sense, unless instance parameters for the window would provide all the variability you need.
Steve Stafford
I would go with face based families if your windows are supposed to follow the dome surface.
sorry to revive an ancient thread... But may I please know how do u create this Pop-Up Spherical Windows? Because I am looking to create one but don't know how to start doing it ![]()
