Revit LT 2023 Project North not rotating all 3D or 2D elements
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
SanctArch
304 Aufrufe, 4 Antworten
Just upgraded to 2023 Revit LT and the Rotate Project North tool is not rotating all 3D elements (furniture, plumbing, special equipment). Also the 2D annotations (text notes, stair direction text) are not rotating (whether I check that option or not). Is anyone else experiencing this? It is happening on two different computers and two different projects.Screen Shot 2023-02-22 at 12.50.11 PM.png
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: SanctArch
Is there a reason you rotate Project North instead of True North?
Nachricht 3 von 5
Those Elements that aren't rotating don't look like they are part of the Activated View.  Are they by chance coming from a 3D View?
Nachricht 4 von 5
SanctArch
als Antwort auf: barthbradley
No.
Nachricht 5 von 5
SanctArch
als Antwort auf: ToanDN
@ToanDN thank you for that suggestion. It worked well in this case. Maybe it will work in all cases. I appreciate you replying!
