My Revit LT 2020 material content library is nowhere to be found. I was planning on reinstalling the whole program (even though I'm skeptical that will fix it) and now I can't even uninstall or repair the main program. I get the following error below. Any thoughts?
Gelöst! Gehe zur Lösung
Gelöst von scottykeck. Gehe zur Lösung
Just a thought is the Revit process running in the background? Ctrl- alt - delete? And end the process see if the uninstall works then?
Hope this helps?
Thanks. Unfortunatley when I close the error window, the revit window closes too. I did manage to uninstall revit using the toolbox. I then cleaned off all my autodesk and revit software and now when I try to install a clean revit I get the same error. I can see that it creates a folder in my AppData/Local/Temp folder when the error window pops up. At that point the install freezes. When I close the error window the whole the install window closes too. I've lost a whole work day on this and am totally unable to install Revit. Not looking good on my end. I'm now thinking I need to reinstall windows 10 all together.
