I have uninstalled the libraries in accordance with the troubleshooting guide and reinstalled twice. Also completely uninstalled Revit and reinstalled.
When using the Paint command nothing loads, the same when initiating the Materials command.
I have opened sample drawings and tested also.
Gelöst! Gehe zur Lösung
Gelöst von Matt__W. Gehe zur Lösung
Hi, @Anonymous. Have you seen this AKN article about the materials dialog not working?
MATERIAL BROWSER DOES NOT LAUNCH WHEN ACCESSED THROUGH REVIT
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
You're welcome.
Don't forget to click “Accept Solution”. This tells others that the answer helped solve the problem and it tells moderators that the question was resolved.
Matt Wunch
Twitter | LinkedIn
