Hi there, my Revit lt 2018 keeps crashing especially when using detail lines, any suggestions on how to fix the problem?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
did you already try to reinstall it?
or els, make the recovery, open it and resave it over the other file.
hello, try to install latest updates from autodesk Revit LT 2018.2. try to tick AUDIT before opening the file. and see if helps. thanks
