Revit LT 2018 Parameter Properties Discipline
Hi, I am new to Revit LT.
In the progress of learning to model families using Revit and found that there was no mechanical discipline in parameter properties.
Is it normal for LT version? If that, how could I model a mechanical families?
Thank you for your answer in advance.
Kimtaurus
This is the Ideas board, I suggest you ask this question in the Forums.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
I thought what made Revit "Light" (LT) was that it has no MEP features.
Kimtaurus
Exactly, the functinalities in Revit LT are limited to Architecture and a bit of Structure.
http://microsolresources.com/wp-content/uploads/2016/07/Revit-Revit-LT-2017-Comparison-Matrix-1.pdf
