Revit LT 2015 not installing application when Revit 2016 already installed
I have Revit 2016 (a student version) installed on my computer, but am doing work experience at a firm that uses Revit LT 2015. I would like to use my laptop with their license and have downloaded and attempted to installed Revit LT 2015 on my computer. However, after having run the setup program, the Revit LT 2015 application hasn't been installed. Only Revit 2016 remains.
The files are on my C: drive under Autodesk, but I don't know how to find or run the application itself. It doesn't show in my programs, and even if I search for "Revit LT 2015", nothing shows.
Any help with this would be much appreciated.
Many thanks,
Ben
ennujozlagam
@Anonymous hello, try to intall latest updates service pack of your Windows OS and see if helps. thanks
go to your control panel > file explorer options > view > and choose show hidden files, folders and drives (if you managed to install your REvit LT 2015?)
Thanks for your reply.
I don't think that's the answer, although I did try it.
Just to explain further, I ran the full installer for Revit LT 2015. Once
the installer was completed however (successfully apparently), Revit LT
2015 cannot be found in the Windows icon program menu in the bottom left
corner, nor can I find the application itself when I search for it on my
computer. Some downloaded Revit LT 2015 files are found located under the
Autodesk file directly on my C drive, but I can't find the application.
[image: Inline images 1]
Further, when I try to run the installer again (which I can find among
those files of course), the installer shows:
[image: Inline images 3]
However, it will not allow me to run the installer anymore, as I cannot
tick the box to install Revit LT 2015 again (despite that the original
installation was successful according the installed when it first ran, and
that Revit LT 2015 is the very thing I'm trying to install).
Thanks again for your help.
Kind regards,
Ben
Um, I believe I've made a very rookie mistake - I wasn't installing the Revit LT 2015 program itself, but just the English Pack for that version. I had thought it was simply the full english version of the program. My apologies for my mistake, and thank you for your help nonetheless.
My intent had been to find the software, download it, and then activate it using the license from the firm I'm working with. However it would appear I can't do this - I must only be able to download the software when signed in with the firm's ID and subscription details. However, if I'm incorrect in this, I would appreciate help.
Many thanks!
ennujozlagam
@Anonymous hello, you can download from autodesk virtual agent. thanks
