Revit lt 16
Revit lt 16
Revit lt 16
I down loaded revit lt16 trial
The first day it worked fine.
Today I cant open the application, it says that the servers from Autodesk are too far or the conncection is slow.
My conncection is fast and is working...I dont know why I am getting this message.
I will appreciate any comments.
Gio
RDAOU
Hello @Anonymous
Do you have a firewall or behind a proxy which might be blocking access to Autodesk?
Hi
I do and I will check that
No it didnt work
RDAOU
If your internet is up and working, and you are sure nothoing (firewall/proxy) is blocking access through port 2589 and that you're able to reach servers Autodesk Servers at autodesk.com (you may try add this to safe/white list in Internet options)' It might be an Autodesk Add-in not being able to access or blocked
Do you have any Autodesk Player Add-ins installed additionally? If yes which?
What is that?All I did was to download a 30 day free trial version for revit Lt 16But I am starting to think that maybe it only works through their networks or servers?Because I can't even find the application of revit in my computer.
Sent via the Samsung Galaxy S® 6, an AT&T 4G LTE smartphone
RDAOU
Oh! you have the online trial...It's either the firewall of your internet security setting. Something is blocking the access to their application servers.
Try add the following to safe/white list in your internet security setting
Otherwise
You can download and install the local trial instead... you can try  Autodesk Virtual Agent
