Revit Lookup Addin Error
1 ANTWORT 1
Nachricht 1 von 2
ashvinkumar2000m
142 Aufrufe, 1 Antwort
"Revit could not complete the external command. Contact the provider for assistance. Insformation they provided to revit about their identity.Autodesk,www.autodesk.com"
"Revit encountered a Exception has been thrown by the target of an invocation."
above error come in revit lookup addin when i am open python script and run it in dynamo.
before running python script it is running fine
kindly please provide solution.
1 ANTWORT 1
Nachricht 2 von 2
BimAmbit
als Antwort auf: ashvinkumar2000m
Though it is quite unlikely that RevitLookup has anything to do with a Dynamo script, you can navigate to the path where the file "RevitLookup.addin" locates and temporarily move it to someplace else in order to make Revit not loading it at startup, ruling out RevitLookup as the cause of the exception at least.
Svetlana Dragomir, Plugin Designer
Partner, Senior Software Developer, Traveler
