This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
Post 1 of 2
Revit Local Server - Cannot Connect
2014 Views, 1 Replies
12-07-2010 11:15 PM
I have successfully installed a Revit Central Server. I also installed two Revit Local Server with mixed results.
All three servers are successfully synchronizing.
The problem comes when any user tries to connect to one of the local servers.
It gets a connect error
“Revit server 10.10.10.89 was not found. Check the name or IP address of the server and try again.”
Central Server – 132.132.0.70 - connected
Local Server 1 – 132.132.8.136 - connected
Local Server 2 – 10.10.10.89 – cannot connect
Does Revit server not work across different IP subnet?
Todd Behning
Merrick & Company
Post 2 of 2
Re: Revit Local Server - Cannot Connect
12-08-2010 05:28 AM in reply to: todd.behning
Make sure that each local server can query the DNS to access the central server name:
There is a potential issue is attempting to connect Revit Servers when a VPN or separate domains are in place.  You may run into issues connecting the local and central servers if each is located in a separate domain.
If this is similar to your setup, one possible solution is to add the host information into DNS.   Then the DNS server can resolve the central server IP address.  Some additional information is organized in the link below:
Please let me know if this is helpful.  Thank you,
http://wikihelp.autodesk.com/Revit/enu/2011/Help/Revit_Server/Revit_Server_Installation_Guide/7Local...
http://social.msdn.microsoft.com/Forums/en-US/netfxnetcom/thread/2a8ca3c8-e1ec-490a-a7e5-5ec533080f0...
Ryan Duell
Autodesk, Inc.
Revit Clinic
@revitclinic
Post to the Community
New Post
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
