Revit load family problems
2 ANTWORTEN 2
Nachricht 1 von 3
225 Aufrufe, 2 Antworten
Hi I am relatively new to Revit. I am currently trying to put some storefront doors from the load family files. However every time I select the doors/windows which I want to use, it doesn't change and still uses the default door and window. I have tried to load family from the door/window ribbons as well as just going into insert to load family. I face the same problem either way.
Hope there is a way to solve this.
2 ANTWORTEN 2
Nachricht 2 von 3
Ilic.Andrej
als Antwort auf: Anonymous
"Storefront" is a curtain wall family. Curtain walls have grid lines, mullions and curtain wall panels. This means that you cannot use a door or a window family here. Create a custom curtain wall panel to get what you want.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 3
als Antwort auf: Ilic.Andrej
Ok thanks I'll try that out right now.
