Revit Lite - Where did the Building Pad Go?
1 ANTWORT 1
Nachricht 1 von 2
dl-DesignStudio
131 Aufrufe, 1 Antwort
Working in 2024 Revit LT and need to cut toposolid geometry like the building pad used to do. Any suggestions? All I see on Youtube is using solids and voids which is not available in LT version, unless I am missing it. Anyone have a work-a-round?
Thx
1 ANTWORT 1
Nachricht 2 von 2
harlan_brumm
als Antwort auf: dl-DesignStudio
For Revit LT, you can create an In-place wall and model a void using those tools and then cut the Toposolid with this void   There are a few other options too -  You can create a family that cuts the site.  You can also use the split tool to create another potion of the site - change its type and lower that section for the building.  Or you can use the Shaft opening tool to cut all the way through the site and then create another Toposolid for under the building.    These ways will allow either simple or more complex geometry creation and offer some level of flexibility.   Hope this helps a bit.
Harlan Brumm
Director of Product Management, Revit Core Capabilities and Collaboration Services
