Revit links file (<Not Shared)>
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mairh_tsek
212 Aufrufe, 2 Antworten
Hello all,
I already found some answers about this issue, but it is not yet clear for me. Why sometimes when I link a .rvt model I have also sub-links?  (<Not Shared)> .
In the case now, I have 2  (<Not Shared)>, and I see the linked model in two different positions.
Thank you in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: mairh_tsek
They are not sublings, but multiple instances of the same link, because you have copied or arrayed the link. It is very common practice, for example you have a link of a apartment unit and you copy it to create multiple apartments in the building.
Nachricht 3 von 3
mairh_tsek
@ToanDN, Thank you a lot!
