Revit linked model - error when add "Number Stair Treads and Risers"
2 ANTWORTEN 2
Nachricht 1 von 3
836 Aufrufe, 2 Antworten
Hi
i've an ARCH  revit linked model inside a Master rvt. file model for make annotation and detailing.
When i trie to add "number stair treads and risers", revit show me an error ( https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... )
this happen only in all views associated in one level  ( basement level in my case )
but works fine in other views of MASTER model and works fine in all views inside the ARCH model.
Someone can help me ?
Many thanks
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: Anonymous
Is the stair in the model that you are working in? Sounds as though it could be corrupt....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
als Antwort auf: Sahay_R
Hi, thanks for answer
The stairs are inside the revit model (architectural model) linked into the file wich i'm working on ( main or master model )
the error appears only in the basement floor level views ( all views, including any new "basement floor" views that i created ).
but all works fine in all other views inside the main model ( ground floor, first story ecc.. )
I thought that the error can be from the stairs in the ARCHITECTURE MODEL, but if i try inside it, all works fine in all view ( basement floor view, ground floor view etc.. )
I try to audit master revit file and arch revit file, but same result.
Many thanks
