Revit link visibility issue
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
357 Aufrufe, 1 Antwort
Please find here attached rvt2017 file
The issue is I cant see any drainage lines once it linked into projects its 2d repeating detail lines
I can see walls in link.
is there any limitations ? or Im missing something >
I checked the categories are turned on.
tried changing discipline as well not sure whats issue
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Hello @Anonymous,
The repeating details lines was considered as annotation that's why you can't see it when you linked to the other project.
If you want to reflect those detail lines when you linked them you have customized the setting display in visibility graphics. (see images)
you have to indicate in the "Linked view" the floor plan in which the drainage detail lines was placed.
