The Revit Link will by default use the Current Models View Settings
If you want to override this and use the Linked Models View Settings (This will use View Overrides and view Templates, Phases, Phase Filters)
Finally if you want to Mix and Match between the the Linked Model and the Host Model you can use the Custom Settings.
*What this does not do is bring in Views from the Linked Model only the Visibility and Graphic Settings
Jay Colcombe
Autodesk Certified Instructor
