Revit lighting
0 ANTWORTEN 0
Nachricht 1 von 1
441101587
202 Aufrufe, 0 Antworten
Revit lighting
I am working on a big project and so the sun light is not enough to showcase the full model when rendering, thus I opted to using lights, I added a ceiling above every ground level by a sett elevation and created a ceiling plan by going to the view panel in the ribbon then calling out the ceiling views, however when I am working on those very ceiling the light componentes that I place are not visible and when I go to 3D view I see that the lights are upside down and  are not lighting the room, I have to chose every light bulb individually and press on the flip work plane option, any idea why and how to fix that? , I have attached some photos to showcase the problem, I would appreciate any help I can get thank you.
0 ANTWORTEN 0
