Revit Lighting Fixture Family on underside of ceiling grid
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
advandes
1876 Aufrufe, 3 Antworten
I have three different rooms, each with a ceiling grid. One room has the light fixtures sitting nicely on the top side of the grid while the other two rooms have the light fixtures below the grid. I have placed the same type grid and the same light fixture family in all three areas. Any idea why this is happening?
AAG
Advance Design
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: advandes
Is the lighting fixture a ceiling based, face based, or work plane based family?
Nachricht 3 von 4
advandes
als Antwort auf: ToanDN
Thanks for the reply. I do not know if  the lighting fixture is a ceiling based, face based, or work plane based family. How can I tell, and how can I revise it if needed?
Thanks!
AAG
Advance Design
Nachricht 4 von 4
chrisplyler
The stock library lay-in fixtures, for example, are modeled with the expectation that you're looking at a reflected ceiling plan when you place them. So if you're looking down on the ceiling from above instead, they're going to be facing up after you place them. This happens to me a lot because I'm designing warehouse space with no ceiling (fixtures hanging exposed) and so I don't ever even make a reflected ceiling view. I just have a view set to the Electrical discipline with the top of the View Range set high enough to see the fixtures. Sure enough, I forget every time, and my fixtures are upside down.
Some of them have flip handles when selected.
I usually just grab them all at once in an elevation or section view and mirror them back into the right orientation. Hasn't caused me any problems.
