Revit Libraries installation
3 ANTWORTEN 3
Nachricht 1 von 4
444 Aufrufe, 3 Antworten
Why is it that every time I load a new version of Revit there is a problem with libraries. With 2016 it was families, with 2017 it was with materials.. With 2018 it is the familiy library again. The only families that downloaded were structural families. Autodesk, please fix this. If there is a special way to down load the program to prevent this, then make that the ONLY way to download and install the program.
3 ANTWORTEN 3
Nachricht 2 von 4
mpeperkamp
als Antwort auf: Anonymous
Hi @Anonymous,
I have found a Autodesk website where you follow howe to download the Content Libraries for Revit 2015-2016-2017:
I think this will also help for Revit 2018, this is an Autodesk install problem I think so.
I hope this while help you whit your problem.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Nachricht 3 von 4
RobDraw
IIRC, I saw something about libraries being a separate download.
Rob
Nachricht 4 von 4
als Antwort auf: mpeperkamp
Nope that did not work. Did exactly as the described in the instructions and got the same partial library as before. See attached pic. Is there an FTP site where I can go to down load a zip library file?
