I have a project that was created off an architects revit model, but I am not sure what happened to my levels. The architect on our project changed the level 3 height, but I cannot find anywhere to move my level 3 height. When I click on a model element there are 4 options of levels to link it to, but can't find anywhere to change that level height
Just wondering if there is a work around instead of having to create a new level and move everything over to that new level.
Gelöst! Gehe zur Lösung
Gelöst von kostask_oionei. Gehe zur Lösung
Hi @NathanMorassut ,
You can try creating Level Schedules in "Schedules/Quantities".
Hope this helps.
Dar
Can you see the levels in another view? Check in a 3d view with zoom to fit and unchecked the crop view.
Turn off any scope box also.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
This can happen when the gridlines have been adjusted within a plan view.
