Revit level not Aligned
htamaki
htamaki
I have added two additional levels to the project, it turns out I cannot align the angle for each level line thus they will never align in the elevation view. The first image is my problem situation and the second image is an example of how I want my level lines to look in 3D view. Thanks revit level.JPG
TripleM-Dev.net
Any chance the Levels (or some) have different ScopeBoxes attached (or had).
To solve it, create a Scopebox in the wanted orientation and attach the levels to it (ScopeBox parameter of the level element)
Afterward optionally set the ScopeBox parameter of the level again to None.
- Michel
htamaki
Thank you! I have set up a new scope box and I was able to solve the problem.
