I'm trying to update a legend, it has louver families in it. It will not update, even if I create a new legend it still brings in the olds sizes of louvers and not the new sizes of louvers. Any suggestions?
@Anonymous,
john.vellek has edited your subject line for clarity: Legend not updating
Gelöst! Gehe zur Lösung
may I ask which product you are speaking about?
Vanilla AutoCAD does not have any functionality with legends.
- alfred -
Hi @Anonymous,
Are these legends blocks with attributes? If so, try using ATTSYNC or BATTMAN to get them to update. If you are using a different type of object can you give more detail or attach a sample file?
Thanks, what I did was save each family as a different one and re put them in.
Also AutoCAD does not know anything about "families" ... which product are you using?
Because of "family" and "legend" I guess you landed in the wrong forum. The question is now which is the correct forum for your question.
- alfred -
>> It's a Revit louver family... Actually from Ruskin...
Well, then let's see if someone can move this thread to the Revit forum >>>there<<<.
As here is the AutoCAD forum not very much people will be able to understand your question and give valid suggestions.
Good luck, - alfred -
Are the old and new sizes in the same family?
If the changed family had the same name, it would have over-written the old family and updated the legend.
I tried overwriting the Revit family at first. But it did not update, When I re-inserted the new louver size, the old size came in. This was a Revit family from Ruskin. Therefore I ended up creating six different families from the original family. Maybe it's just an awkward family. But nevertheless, I fixed it and I consider this closed...
