Revit keeps crashing
2 ANTWORTEN 2
Nachricht 1 von 3
289 Aufrufe, 2 Antworten
hi all
Just wondering if anyone might be able to help.
I installed Revit 2018 with success yesterday.  I have notice that when in Projects -- in particular when using Model in Place - Creation of Extrusions, and using Model Lines the software keeps crashing.  It is very frustrating as I keep loosing my work that I have been working on each time.
Anyone have an ideas why that might be?
I have send 4 reports to Autodesk and just wondering if it is something that I am doing wrong.
Thanks in advance.
Helen
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Are you hosting to Reference planes? Most of the time these crashes are due to faults in join conditions and constraints. If you create reference planes to host your extrusions, it will be less likely to crash and easier to manage.
Nachricht 3 von 3
ennujozlagam
try to install latest updates form autodesk, uncheck use hardware acceleration from options. before opening the file check audit first and see if helps. thanks
