I am trying to render a 3D interior view of my project for my final and the render is showing black.
My troubleshooting consists of the following.
Can someone help suggest another solution? My project is attached below
Thank you.
you do have issues with the exposure value of the renderings
** also you do need to insert more lights and tweak the intensity and reach of all of those
for sun only try to modify exposure value to see the rendering
with artificial only you do have same issue
try modifying the exposure value as well
you have too dark this value all over the images
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
I tried making the changes you suggested as well as changing the lights I placed because 17W was too low, but I am still getting a black box.
delete all your lights in the project
these are causing that you can not render it (they are badly done in REVIT)
replace those with the one I'm attaching
it will work
and also adjust the exposure value in general
aRcHiTeCt.JM
REVIT EXPERT ELITE
Choosing a different IES File for the "Lighting_Fixture-Lutron-Recessed-Finire-3in-Round-Downlight.rfa" seems to correct the Rendering issues at my end.
Can you post the "Finire RD DL HO 2700K 28 WH No Glass.ies" file?
FWIW: I'm seeing no issues with your Light Fixture Families. They all Render fine on my end.
Draft, Artificial Light Only Renderings:
Entertainment:
Suspended:
Recessed:
