Revit is not responding
An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files. It will not run revit after this. Any suggestions?
dzanta
is this occuring when you open revit or open a revit project file?
if this is happening when you are starting revit, try doing a repair on revit (Control Panel, Add/Remove Programs, Revit, Setup Window, Repair)
if this is happening when you are opening a revit file, start with Open, then click Audit box in lower left corner of Open box, then click OK to see if it can be audited/repaired
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
